DC OUTLET
8et-w8192-00-kt $72.56 CAD is the kit, says 09-10 nytro though so i would call the dealer to find out
I bought a non-yamaha, and saved 90%, looks as good as stock. Get a "Marine" versjon, it has a rubbercap.
Fitted right in the hole :)
Insane price on the original, atleast here in Norway.....
2nd rami... I added a second one, purchase on ebay for hardly nothing. Make sure it is marine grade.
08 nytros do not have the factory plug,I found out after I bought one.I cut the plug off and wired it to the battery.
Hmmm, where? biltema?
I'm going to install a 2. one parallel to the "outside"-one under the hood and vulctape the Garmin Charger in it and just route the cable out.
Have to meashure the amphere it draws when nothing is connected, if it's to much, I'll install a switch on just that one.
I did that installation on my Nytro. I mounted a relay before the garmin plug, so that it only gets powered when the engine is running.
And i mounted a separate "outside" with a fuse directly to the battery, for charing of the sleds battery.
Mekkonomen: 75,- NorwegianOilmoney ;)
Want the Garmin to have power on all the time it's plugged in, the Garmin Colorado eats battery
(And for the record, I dont recomend the Colorado, but I'll post something about that in the GPS-part of the forum later..... :o| )
got a link for what you used?
mach9 said:
What are all you guys plugging in to power up?
Naah, you know, haidryer, leghair-remover, masageseat-overlay, electric Wonderbaum and a winecooler, wilderness, here I come!
:drink:
i use it to give my truck a jump.. Damn i need new batteries
but honestly, heated visors, heated gloves or clothing, GPS, MP3 players..
I don't really have one yet but i gotta do something for my GPS, 2AA per 3 hours is noo good!
