jlbpropilot
- Dec 21, 2010
Can someone save me some time in trying to locate which fuse goes with the DC pwr supply and where it is located? I have my heated visor plugged in there and it doesnt work anymore. I suspect the fuse got blown. Thanks
joeapex
Remove the right side body panel, fuse box is at the top close to the coolant bottle, the fuse you are after is in the middle, should be a 3amp fuse. There is a legend under the lid of the fuse box to point you in the right direction and spare fuses in the holder attached to the fuse box. Went through the same thing on two machines on Sunday.......
SLEDSTART
Your fuse box is in front of your right knee by the reverse mech and along the steering gate (bar around the engine). Not that many fuses there to check. I think it's the 3rd one down from the top labeled DC TERM
jlbpropilot
- Dec 21, 2010
Wow you guys are quick, thanks a ton.
