xtxer
- Feb 27, 2012
Went to start machine, pulled up on the kill switch and turned the key. It turned over for about 1/2 a second then nothing!! tried again - no instrumentation no power anywhere. Tried boosting it - nothing. Checked battery - fine. ckecked ignition connection at handle bars - found 12 volts. Still nothing. Checked fuses - all ok. HELP!!!
Indy
while holding key in start position with the kill switch pulled up, start wiggling wires around the starter relay, If you get a bump, then you've most likely lost the main ground.
xtxer
Please refrain from double posting from now. Thank you!
xtxer
- Feb 27, 2012
First time user my apologies
xtxer said:First time user my apologies
Understood and no problem. Welcome to the site!
xtxer
- Feb 27, 2012
I wouldn't have believed it. Wiggled the relay closest to the tunnel while holding the key to start and after a couple of wiggles boom!!!!! she's running! Thank you Indy!!
Indy
You are welcome. Now you should inspect the wires in that area. This has happened to me twice. 1st time really stumped me until I brought a friend over who is a reitred military machine electrician. All he did was to make a jumper wire to re-ground the relay to the frame and varoom. So if you cannot find the problem wire, run a new ground.
Kaz
Sounds similar to the problem on the Apex's with the grounding blocks over time.
http://www.ty4stroke.com/viewtopic.php?t=83994
Check out the above post.
Kaz
Kaz
