phatkid
Well I finally got my trail tank back in with some great suggestions from all of you so now on to my second problem .....
when I first tried to put trail tank in I must have bumped something and I lost all power to the sled?
i removed the tank again and started messing with all the connections under the hood nothing seemed unplugged but I got power back somehow???
well now I have power back at the key i.e. dash light up fuel pump runs etc
well the engine wont crank no clicking nothing??
battery is fully charged and battery terminals are tight
could i possibly of ruined the starter sylonoid? anywhere else to look to trouble shoot the problem??
I have no codes up on the display either....
any help again would be great , thanks again for all the support you guys give us newbies to the 4 stroke world
Jammie
Jammie
Sledtime9
Silly question, Did you check the kill switch on the bars?
phatkid
Yes, valid question ...... I did check the kill switch if it is pushed off the dash will not light up until its pulled out
thanks though.....
thanks though.....
Straight_up_XTX
How about checking the starter relay?
I know people have had problems with it getting wet and freezing up... maybe yours is sticking.
Just a though.
Just a though.
phatkid
gonna look at that too as its been in my heated garage all season but could be wet for sure as i washed it not too long ago
jammie
jammie
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
X2 starter relay...
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
check the connector coming off the ignition switch. you may have pulled it apart or it's corroded. Normally when the stater relay goes bad it will click but not roll the starter. I bet you're not getting a signal from your key switch to the relay.
