CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
Put Slim Jims on the original Yamaha OEM skis and its even better. We will be doing the same on my sons 2016 Vector by removing the Tuner 2 skis and installing the OEM's with Slim Jims. Absolutely no darting and with silky smooth performance.
Do you find the Slim Jims are better then the Original duallys?
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
I do. I think the Slim Jims steer easier than the original Duallys and I have used the Duallys in the past with very good results.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
I should try them.. what the heck..... no problems with rail crossings or payments?
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Well, crossing rail tracks are always a problem with any setup. I have been thrown from my sled years ago. Much more careful now.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Never had any problems here. I always try to cross at a right angle to the tracks....or as much as I can.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Try both back to back on the same day and tell me the 129 is better! HAHA No chance. I was a huge 121 defender and once I went long I have no idea why I stayed as a 121 for so long. I had 241 hp on a 121 and when I went to the 151 it was like I had 340hp. Insane change in traction, better over bumps, etc. I guess that is why they give you options. My comment on why even make a 129 was more around the idea that if your riding in such tight conditions where you need every ounce of maneuverability you could get, you probably don't need the 204hp
I was spinning my 121 at 70+ mph when I would floor it and didn't know it until I got the 151 and it almost ripped the sled out of my hands on the first pull!
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Thanks Kinger for getting back on topic....my original plan was to go 137, but a couple of buddies are snow checking new sleds also. One is going with a 129 SW and the other is going with a 129 T-cat or ZR 9000. I started to question my choice but after reading the reviews I'm staying with my original choice.....the new sled will be the L-TX-LE 137 50th in Red!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
good choice
kinger
- Jan 17, 2005
- Clear Lake, IA
Drooling over your choice. Enjoy!!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Great choice , as I have the SW LTX LE 137 49th in red !Thanks Kinger for getting back on topic....my original plan was to go 137, but a couple of buddies are snow checking new sleds also. One is going with a 129 SW and the other is going with a 129 T-cat or ZR 9000. I started to question my choice but after reading the reviews I'm staying with my original choice.....the new sled will be the L-TX-LE 137 50th in Red!
