kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I cannto find it anywhere I searched and found a link but it says the post does not exist and the posts i got the link from were back in 06. Just wanted to read up on how to get into the spark plugs, buying a SC apex this weekend and want to do a CR check and leak down test. Thanks!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
dave_dj1
thank you , I want to change my plugs anyways
kinger
- Jan 17, 2005
- Clear Lake, IA
Thank Allen, how did you get there I was in the tech center and couldn't find that apexinfo folder? That is a nice write up!
niko
cant seem to find the rest of the post?? It stops at the airbox removal.
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
The post shows you how to get to the spark plugs, but doesn't actually tell you how to remove them. It's pretty evident once you get there though. You do need to remove the coolant reservoir.niko said:cant seem to find the rest of the post?? It stops at the airbox removal.
When you first see the arrangement, you may think that getting the plugs out isn't possible. It is, but it's hard.
p.s. -- you don't have to remove the airbox to get to the spark plugs. You probably knew that, but.....
- Apr 17, 2003
- Menno, SD
- Menno, SD
Oil & filter change instructions (this was actually for our oil filter relocation kit).
http://www.ulmerracing.com/Complete.pdf
