SJYAMAHA
Can somebody list the differences between the 09 and 2011 Nytro XTX?
Thks
Thks
2 years...lol
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
hmmmm bold new graphics, new and improved handwarmers hahaha
SJYAMAHA
I see they moved one set of idlers ahead, just comparing them in the garage anything else ?
LM7800
- Dec 4, 2011
- ohio
- 2016 viper ltx LE sold
10 on had removeable bearings in boggie wheels, hand warmers were upgraded in 10 as well
SJYAMAHA
Do the 2011 handwarmers work or should I be putting Yamaheaters on?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
SJYAMAHA said:Do the 2011 handwarmers work or should I be putting Yamaheaters on?
Yamaheaters are a must have unless it doesn't get real cold or you like cold hands.
00-NUKE
sorenson1610 said:SJYAMAHA said:Do the 2011 handwarmers work or should I be putting Yamaheaters on?
I disagree. My stock 2011 hand warmers have been really good. The coldest I've ridden in this year was -19 degrees F and I had no problems.
hittoomanytrees
I find my 2011 hand warmers get plenty hot enough even in -30C. The only complaint is they take a while to warm up.
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
In 2011, they relocated the torsion spring mount off the idler wheel and into its own separate bracket. Mach9 picked up on this, and I did the 2011 update to my 2009 as well. Now that the spring has its own mount off the wheel, I was able to shift my wheels around and add some extra ones up front where needed.
LM7800
- Dec 4, 2011
- ohio
the 2011 warmers are better but still not like they should be. Like the old days of the v-max and srx that would burn your hands. I filled my bars with spray foam that helps, but I think i'll be ordering yamaheaters
Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
My hand Warmers work great on my 2011 rtx. No complaints here.
Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
SJYAMAHA
Wondering what you guys are doing for torsion spring spacers buying the Hygear spacer or making your own?
