Meadowbrook
- Dec 19, 2009
After the hyfax wear from the small 5.125" Yamaha wheels, the dealer installed 5.350" wheels but that was not the answer. I found 5.25" wheels from the cat dealer and they really appear the right balance of supporting the track and allowing some contact with the hyfax.
I had the rear wheel blocks milled down 1.5MM and this appears to allow the wheels to run in the center of the lugs. I will report after some long hi speed runs.
Thanks to everyone on this forum for pointing me in the right direction to solve the problem.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Meadowbrook
- Dec 19, 2009
I know that a lot of owners used the doo 135mm wheels with good results. After looking at the track contact with the 135mm wheels, I was apprehensive that the excessive space between the track and the hyfax would cause rail stress and excessive wheel wear. This may be totally unwarranted concern but after installing the 5.25" wheels, they just seamed to fit right.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
On the inside of the rails at the front wheels there is a machined piece of billet aluminum running the front length to reinforce the rails. Look at the conditons I ran on Saturday and there was zero wear on my sliders.
Preacher
Mighty, did you have to machine anything or do the doo wheels just replace the Yamaha wheels.Thanks
Preacher
Mighty, I saw your other post,it answered my previous question. Thanks
quebec#1
SharkAttak
135mm doo wheels have held up for 4 years for me
tkjetta
Did you have to machine anything when you went to the 135mm doo wheels? Thanks
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Mighty, your suspension reminds me of this song:
http://www.youtube.com/watch?v=4GhQWeZSg9U[/img]
apex55
Mighty, your seat looks like a humpback whale. Can you shed some light on this?
SharkAttak
apex55 said:Mighty, your seat looks like a humpback whale. Can you shed some light on this?
that poor seat is taking a beating
SharkAttak
tkjetta said:Did you have to machine anything when you went to the 135mm doo wheels? Thanks
inner wheel holder 1.5mm-2.00 so they don't rub
