does a 04rx1M have both a tors and tps?
MtN_Rx1er
Cupar,Sask,Canada
just curious if a 04 rx1 mountain has both t.o.r.s and t.p.s, i know of the one thats on the throttle body(idle screw) just not sure if it has another one, mine keeps getting tripped off but when i plug the wires into themselves it runs great.just trying to troubleshoot what to look at next since i cleaned and inspected the one on the throttle body.
Crewchief47 said:
Tors switch is on the bottom of the idle screw area, tps is on the end of the carb rack.
http://www.portyamaha.com/fiche_section ... &fveh=1277
TORS is #47, TPS is #67
There is another TORS switch located in the throttle flipper housing just so you know.
thanks for replying, i didnt even realize there is a tps on the carb rack,where does this one go? is it to the throttle or the throttle tors is separate fro #67?, i took # 47 (tors switch ) off and cleaned it, it looked like new so that cant be the problem, is there a way to diagnose wich one is tripping the tors system? it idles fine but as soon as you give it gas it activates it
