chadman
I need to get the rpms up on my 2012 apex. I am jumping to 10100 ish out of the hole and will slowly go to about 10400 and will not go any higher and I will let off at 85 mph. Where do I need to take off weight to get the rpms up? I only have 330 miles on this sled and I know that it is not fully broke in and things will change but I can make that adjustment when that time comes. I extended to a 136 and went to a 23 tooth top gear.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Post your current weight placement and I'm sure someone can help.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Not much experience with the flys but I would take a gram off mid range and one off top end as they call it in the instructions. Then see where you get to after 1,000 mi.
Were you on good hard PAC? They will usually run more RPM the harder the PAC is also.
chadman
I was out on a lake and there was 3 to 4" of drifted snow and some small bare ice spots but, mostly snow. The problem I have is not knowing what section of these weights controls what area of the rpm. My engagement is where I want it to be and my rpm stays roughly the same, I just need to drop a little weight at 1 or 2 areas.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Based on Heelclickers recomendations, and assuming you have the short track set up, you could remove 2grams from the overdrive and 1 gram from the center locations. Also you may want to try the same secondary spring/helix as the Attack or even the XTX to see how they differ. This might seem dumb, but an over tight track will pull rpms also.
nutnbut4stroke
- Feb 3, 2013
Best advice is to call Allen at ulmer racing and let the clutching be done by a professional.. trust me and others..he can help you without throwing money away. Jm2c
chadman
I had talked to Allen and he said putting the weights from my 07 apex into my 2012 should be fairly close and only have to make some minor adjustments on the weights.
scott32
- Jan 12, 2009
The attack 136 uses a white secondary spring at 60 wrap.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What is your current set up?I need to get the rpms up on my 2012 apex. I am jumping to 10100 ish out of the hole and will slowly go to about 10400 and will not go any higher and I will let off at 85 mph. Where do I need to take off weight to get the rpms up? I only have 330 miles on this sled and I know that it is not fully broke in and things will change but I can make that adjustment when that time comes. I extended to a 136 and went to a 23 tooth top gear.
