vote4pedros
What is the best setup for drag racing? i guess a loose limiter and setting the transfer rod up for more weight on the track would be ideal correct? Front shock psi make a difference? I noticed alot of track spin off the start. I have 144 studs on ripsaw. Rumble pack exhaust, other then that it's a stock 06 RTX. I got beat on 2 occasions by 04' 800 revs even at the top. We went about a 1/2 mile. Not impressed. Anyone know the gearing on the 06 RTX? and shouldn't i be eating an 04 rev for dinner. The conditions were 2 inches of hard snow on nice.
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
you must have a slow APEX...........
gear down 1 tooth on top,you will have better low end and will still have the same top end, what were the snow conditions? the ripsaw is only good on hardpack
SledFreak
- Feb 7, 2005
- Ontario. Canada
Put the limiter strap in the stock position. Set the transfer rod to max. Change the gearing to 22/38 or 23/40. You should be running 168 studs for drag racing, which includes the outside belt. THIS IS THE MOST IMPORTANT THING TO DO WITGH THE STOCK TRACK. MAKE SURE YOUR STUDS ARE 1.450 WOODY'S MEGABYTES. 1.325 or other brands 1.375 are just not long enough and you will spin ALOT. Make sure you Full synthetic oil. 0-20 or 0-30. Try that out and see how you do. If you need more help, we can talk clutching. There is no use doing that until you have traction. Let me know how you make out...
vote4pedros
Whats the stock gearing for the 06 rtx?
SledFreak
- Feb 7, 2005
- Ontario. Canada
24/38
vote4pedros
So the cheaper route would be 22/38 just have to change the top gear. Alright!! Thanks for your help!!
SledFreak
- Feb 7, 2005
- Ontario. Canada
That and the studs is the key.... The length of the studs for sure..
agaguk
With 22/38 you need a 68 link chain. if you want to keep the stock chain your better to buy both gear(23/40)!
vote4pedros
So would buying the 2 gears (23/40) end up being less expensive then the top gear (22/38) with a chain?
SledFreak
- Feb 7, 2005
- Ontario. Canada
No, I believe the chain and gear is cheaper, since the the Reverse bottom gear is expensive and the bearing is extra. This is only true if you have reverse? Do a search in the classified, I believe there was somone selling that combo. I'm not sure if it's still available.
vote4pedros
k thanks!!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
40 tooth reverse gears for $127 with bearing installed from us here at Ulmer Racing!
