Drive Axle
SnowBandit
Maine
Website
www.slednewengland.com
2009 Nytro xtx
Is there any where to get a new drive axle with the drive sprockets(or what do you call them) already on it? I can run exovert drivers as my track has closed every third window.
Or is it easy to get new sprockets on?
To run extrovert drivers you need ever window open -- for the outward pointing cogs to go thru and spin the track. You could cut your closed windows open if wanted to install extro vert drivers.
A lot of guys switch to extrovert drivers when they swap out the stock drive shaft. A lot of places sell drive shafts with drivers already attached. Ulmer is a good supplier. You can also contact Micro Belmont in Michigan or Wahls, and get a larger diameter heavy duty shaft with extros already pressed on. This is highly recommended as these are not the type thing you can press on in your garage.
I am not looking at making the switch right now to extro drivers as I don't want to have to cut every window open. Then wouldn't I need to place clips on those windows too?
Do you know if they offer the heavy duty shafts with non extro drivers?
You don't have to clip the track windows but do need them (windows) with extrovert drivers. And if you prefer regular drivers, you can have them pressed onto a larger diameter, heavy duty drive shaft, you bet.
