welterracer
IM selling my 04 warrior to my brother... IT currently has 3500 miles on it..
SHould i be worried about the drive shaft or jackshaft bearings going out on it...??
I havent had any problems with the sled and even the originally boggy wheel bearing look great..
DC5
After 4000 miles my jackshaft bearing was in good condition but my driveshaft bearing was toast on my 04.
Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
Best thing you can do is to take the seal off both bearings and check there condition, then grease them at least every 2000 miles/each season.
So do we only have to worry about the clutch side bearings??? I have 4,000 miles and I will be checking the bearings on the secondary side. I assume you cannot easily check the other side. If the clutch side is OK there is no worry ????
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
How do you "check" a bearing? If you're gonna go to the trouble of checking them, change them. It's not that hard.
Tom-RX1
9,000 miles on my 03 going to change this year just for saftys sake .
Tom-RX1
Tom-RX1
