Alatalo
The 2008 and 2009 FX Nytro drive shafts have got different part numbers (8GL-47511-00-00 and 8GL-47511-10-00). Does anybody know what the differences are and if they are interchangeable...? I have heard something about an updated lower sprocket bolt, is the shaft updated because of this...?
yammi4ever
they look the same to me, but may be some subtle change.
big_red1a
Maybe the diameter???? I have heard that the 09 apex uses different size driver to fit on the jack shaft
garserio
- Nov 30, 2004
- Fairport, NY
- 2014 SR Viper
2001 AC Z370
2006 AC F120
Alatalo said:The 2008 and 2009 FX Nytro drive shafts have got different part numbers (8GL-47511-00-00 and 8GL-47511-10-00). Does anybody know what the differences are and if they are interchangeable...? I have heard something about an updated lower sprocket bolt, is the shaft updated because of this...?
Typically the 3rd element of a Yamaha P/N is a configuration code. For instance, a colored part will have the same P/N except the blue version might be a -00, the red a -01, the black a -02, etc. For a hard part like a shaft, they might have changed a plating spec, a tolerance, a metal alloy, etc. The parts are geometrically the same, but there is something different that you cannot see. The new part (in this case -01) would be backwards compatible to the -00. It is quite likely that the -00 is no longer available and replacements for a -00 would have to be the -01.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
xxx-xxxxx-10-00 tells that it is a upgraded part that replaces the xxx-xxxxx-00-00 part, thus the parts are interchangeable 100%. To find out exactly what the upgrade consist of you have to have access to the Yamaha dealership network system, your dealer should be able to look that up... if they have the time...
