Drive shaft removal question
Fullback
Millerton, New York
I'm installing a new track and have the drive shaft housing mounting bolts all out and am having trouble removing the housing from the drive axle and the secondary shaft. I have the circlip off the bottom bearing but the drive shaft still won't slide out. Is that bearing pressed on, and how would I get a puller on it if it was? Any help would be appreciated... Thanks
No, it is not pressed on. You really have to reef on it, it will come, but it is on there very snug. Use a rubber mallet or get a pry bar in there, it will come...BBY
