driver shaft, bearings
aceltx09
New Hampshire
What is the shaft with the drivers on it that is turned by the bottom gear called (turns the track) Is that the jackshaft. Does anyone know were I can find a step by step on changing the bearings on each side. I'm pretty sure one of them are fried on my buddies RTX Took the chain case apart and cannot turn that shaft.
You need to take the chain case off the front and back. Then on the left side you have to remove the speedo gear 3 bolts pull off the gear and cover. Then on the inside of the tunnle on the left side you have to take out the 2 set srews in the bearing. then pull the bearing out.
When you say front and back of chaincase do you mean inside the tunnel. I have all the gears and chain out.
