Removed the driveshaft bearing today to re-grease. Having a heck of a time re-installing the bearing because the driveshaft has shifted out of center to one side. Is there an easy way to remove pressure off the drive shaft to re-install the bearing?
Thanks,
Try loosening the track all the way, If that doesnt work you will have to take the skid out. Take caution of the seal on the chain case side not to damage it. Hope this helps.
If you loosen the track, you should be able to move the driveshaft enough to re install the bearing. I assume you are referring to the driveshaft with the drive sprockets and not the jack shaft.
