Bluemagic
- Mar 12, 2007
I know the 05 lost about 25 pounds over the 03/04mostly in the rear suspension, what other mods can be done to loose weight and cost?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Here is a sheet I put together:
RX1 weight loss Opportunity 605 Weight Cum % Weight loss
CB perf monoshock 23 lbs 29% 23
excell Exhaust 15 lbs 48% 38
Battery 10 lbs 61% 48
A arms 7.7 lbs 71% 56
seat 6 lbs 78% 62
Fox floats 5 lbs 85% 67
Hood 5 lbs 91% 72
Steering post 2.5 lbs 94% 74
Spindle 2.2 lbs 97% 76
Brake hub and rotor 1 lbs 98% 77
Tie rods 0.7 lbs 99% 78
Heat shields under seat 0.5 lbs 100% 79
New dry weight 527.6
Total weight loss 78.6
It starts from a 03 though which had steel upper a arms and the 14lb heavier rear skid. I would look into a battery, fox floats, and a boss seat
seat 6 lbs 78% 62
Hood 5 lbs 91% 72
