![](/styles/vip.gif)
Mtnviper
Vendor
Normally when using hyperfax or hyfax with teflon inserts, tracks that are not fully clipped should run buttons or fully clip the track.
link to what track buttons look like http://www.startinglineproducts.com/cat ... ductID=488
LoneViper
I'm wondering how these would work with an A/C Powerclaw, all windows open but only clipped on every other crossbar. The rubber has huge friction.
tomseal6
interesting,
might add these onto the nytro. I think every 3rd on the 121 is clipped. why dont they fully clip from the factory? that is crazy. u wear out your track faster, less lubrication and you cant extrovert drive your sled.
Is there some sort of center tool for these to get perfectly in the middle?
essentially it looks like a carriage bolt you can buy at the hardware store for much cheaper
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
You can run extroverts on a track that is only clipped every 3 rd window, i did last winter. I was told its fine to do unless you run boost then its a must. I do plan on running it fully clipped this season though
- 6K
