actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Its time to replace my Sidewinder battery. Which Earth X are guys using and any reviews are appreciated.
Jack
Jack
Robrstopr
- Dec 20, 2018
- wyoming
- 2018 Sidewinder MTX
This one...#*$&@ Pic wont post to big..
EarthX…. EXT36D in my Winder MTX...zero issues and almost 10 pounds lighter than stock..
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
What’s it weigh? Stock battery over 10 lbs?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I had the same earth x in my viper! It's going in the sidewinder this year. When I took it out at the dealer when I traded it I tossed it to the machanic! Should have seen the look on his face when he caught it! It weighs nothing really
EarthX. ETX36D
WinterWolf
- Mar 25, 2017
- Connecticut
How much are these Earth X batteries? Are they more powerful than the stock battery?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
If you ride in the cold and don't have the sled stored in a heated garage you will have problems. Lithium ion batteries do not like the cold. These sleds need weight taken off the front of the sleds and not the rear anyways.
Robrstopr
- Dec 20, 2018
- wyoming
The Earth X weighs 3 pounds 13 ounces cost me like $350.00. OEM was over 12 pounds if I recall. I can find the pic I took of the weight.
Never had an issue with EarthX in cold weather and left outside of cabin in -15 degrees and fired sled right up. Its powder no liquid. They advise in extreme cold to turn key on let gages cycle...turn off repeat but once gages cycle turn key start. The cycle put juice through the powder to warm it and then it fires. I personally have had zero cold weather issues. Sled sits out side of cabin for days at a time in the Snow Range, Togwotee, Crooked Creek, and in Alpine Wyoming while on trips. All day trips its in enclosed trailer.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
There is some truth to this, but the new generation of Lithium ion batteries is MUCH better. They can function in -20 F.
And you're right about the weight. I personally need weight in the back............so i replaced the weight from the battery & put a 3 gallon gas tank back there.
I'm not sure the $350 is worth 10 pounds in the back to some people, but it seems i'm not the only one with OCD on this forum.
hellflyer
- Dec 2, 2008
I replaced the stock battery because it started leaking after the first year. Had a hairline crack that lost a couple drops a month and didn't trust it. The eathx does crank faster when it's warm.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I agree Steve your not the only one but you are our leader....LOL
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I had an earth X in my Nytro and the first time I went to cold start the sled (-5F), it cranked slow. I called earth X and they explained that as the earthX cranks the engine, it warms up (you need to keep cranking it). It warms quickly and it’s spinning the engine at a normal speed soon after you start cranking. It’s weird though. It was trippy to get used to a battery that produces more power as you crank it, not less. The EarthX never failed me but I only had the sled for two seasons. I’m buying a new battery this fall for my XF7000 and it will not be an earth x, but that’s because it’s $350, not because it didn’t perform as advertised.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I used a 2lb battery then added a Ultracapacitor to it (another 1lb) and the UC charges and discharges extremely fast. It helped warm the lith ion but allowed really fast cranking even in cold weather. Worked slick and will make its way back into a sled at some point. I had a issue and had to crank the sled a LOT amazing how the lith ion never ran out! Just went on forever!
Boston RX1
I need to replace me battery and I am thinking of this new EarthX. I purchased one for my motorcycle and it has worked well. Can't believe how light it is. This new model is made for snowmobiles. Thoughts?
https://earthxbatteries.com/shop/ETZ14C
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I like it! Need to replace my Shori Lithium that gave up the go last season, this will fit the bill well. That Shori lasted me 8 years! I found when going back to the stock battery my rear suspension bottomed quite a bit more it was so heavy compared to the Shori Lithium. People might not think 12 lbs makes much of a difference, but it does to me in the suspension department alone.
