Electric or mechanical Boost gauges
BOOST
MT
Not talking about digital boost gauges but what are most of you running as far as boost gauges??? The electric ones with peak and warning or just the mechanical how about liquid filled? Just curious as to what most are running
Liquid filled Auto Meter boost gauge. No problems so far...........
Not sure if I trust anymore electrical things on it!!!!!!!! :o|
AutoMeter boost gauge reads both vacuum and pressure up to 30 lbs. Not liquid filled, needle bounches around at idle and low rpms, from engagement the needle is pretty stable.
I run the autometer C2 eclectric boost with vac. It was about $200.00, but worth every penny. Stands up to the weather and the beatings on the sled. I have the entire matching set, a/f, water, boost.
