electrical help
ogre
SW Ontario
First off I know this is not the Sxr message board, but I really need help.
I have a 2001 SXR 700 and with the high beam lights on the sled runs rough and all lights flicker and go dim. Last season I installed the updated fuse & wiring assembly for this problem. Is it possible that it could be the fuse assembly again or some other problem. Any help would be appreciated
did you go with the higher voltage headlights? Could be robbing power the engine needs.
