Dmarks
- Jan 9, 2014
What are we using out there to top off systems. Had a hose clamp leak out coolant on my 15 and I need to top it off
I use Yama-Cool
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
- 2017 Sidewinder LTX
Preston mixed 50/50 with distilled water. I change it every year... I know... just what I do. lol.
B.anderson14
What's from the factory
09nytro
Not sure what the brand name is but it’s green automotive anti-freeze
Bucky582
Like said earlier, I used the Yamaha Blue Antifreeze, mixed 50/50
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
From being a mechanic over the years, coolant is coolant. Many aftermarket brands make there stuff so it goes along with what you usually have in your engine, use something 50/50 similar color. Napa stuff, advance, prestone or Yamaha works too. But Yamaha doesn't reinvent the wheel. Coolant is coolant. Just an opinion for what it is worth
B.anderson14
Thanks just wanted to make sure
viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
It specifies in the manual..but i would replace all coolant in the system with evans waterless coolant..it causes no pressure build up in system, like regular coolant does. You will never have a leak or burst hose due to pressure build up.
Obviously hose clamps need to be tightened properly.
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
Can you tell me total amount needed for a change? With or without dilution?Like said earlier, I used the Yamaha Blue Antifreeze, mixed 50/50
TIA
