beamer123
- Dec 18, 2016
- Michigan
- Yamaha FX Nytro
2009 Yamaha FX Nytro all stock. Ran great last winter. Over the summer battery went dead. Put new battery in today. Started right up, and I let it warmup until oil light went off. Ran it up the driveway and the engine icon came on and the yellow warning light is flashing at about 20 mph, sled stopped but kept running. I let it idle and icon and light went off. Rode back to barn and shut it off. Waited for about 20 minutes and tried again. Was able to get it up 30-35 mph and it did it again. Starting and idling it seems fine and under 30 mph. No other icons, fault codes come up. Checked all connections after I put new battery in and all seem ok. Any ideas
Thanks Brian
Thanks Brian
aproudcanadian
- Dec 18, 2016
- new brunswick
- 2020 ski doo 900t x
any fault codes coming up on dash?
beamer123
- Dec 18, 2016
- Michigan
- Yamaha FX Nytro
no other warnings, or no fault codes. However I did not check engine oil level. wanted to see if it would at least start with new battery, before heading home. would low oil level cause this type of problem?
Dr. FeeLGooD
Crappy stale fuel would be my first guess.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
X2 on crappie gas or low on gas if no codes.
Pete
Pete
beamer123
- Dec 18, 2016
- Michigan
- Yamaha FX Nytro
I drain most all gas out of tank at end of riding year. Just put 5 gal. of fresh premium in. So low gas would not seem to be an issue. However Stale gas from fuel line(s) - injectors would make some since. When i head back up i'll run it some more to see if problem goes away. Thanks
Dr. FeeLGooD
dump in a little seafoam
Dr. FeeLGooD
