rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Started the sled today..had it out running a few days ago. Started right away..quit...turn key off started it again..once again started right away and idled fine. Got a flashing yellow light and engine symbol and the rpm would switch between rpm and 81..any ideas..
https://ty4stroke.com/threads/fx-nytro-faq.58910/
and then you will see link in there: https://ty4stroke.com/threads/fault-codes-relay-fuse-location-wire-diagram-diagnostics.83992/
rev them up
- Apr 3, 2006
Great thanks
rev them up
- Apr 3, 2006
Went into diagnostic mode..cleared the codes..still showing code 81. I can adjust the temp of the thumb warmer but the hand warmer will not come up. Sled also has yammi heaters on it. Any suggestions on what to unhook/change to get the 81 code off and get control of the handwarmers.
Bring up the idle and see if it goes away, if not disconnect the RockBox or contact @Rockmeister
rev them up
- Apr 3, 2006
Thanks will give it a try tomorrow
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Call Roc....he will walk u thru it over the ph. My thumb booster faile last fall, and he helped me diagnose it in 5 mins. New one sent out that day.
- 11K
