timc
I ran my '07 Attak this past weekend in VERY cold temps. -40 or so. It started suprisingly well. I let it warm up to 160 or so and within the first couple miles I had a green warning light come on and the engine went right to an idle. After several seconds, the light would go out & I had full throttle. It happened three times within those two miles and never bothered again on an 80 mile ride. There was a symbol that would blink in the display. I looked it up and it talked about checking electrical connections. It said a code would appear in the odometer but without glasses I couldn't see it and it went away too fast to figure it out. Any ideas?
LJ 452
Should give you a code number, my guess would be tors. That would limit your throttle to near idle. You'll need to check the cable routing, if you put on a taller riser you may need to go with the mtn. cable to give you more length. Again, you'll need to see what number pops up on the speedo.
