jromain
- Nov 22, 2009
I have an 2009 Apex LTXGT
at times my triangle warning light comes on and the engine symbole is displained on the screen, the engine goes to an idle, I have to shut down the engine and restart in order to reset.
this problem occures only at times example once every 250 miles.
has anyone seen or hurd of this problem and how can I retrieve the logged codes.
Jocelyn
Jocelyn
SnofishersBuddy
Any codes flashing? If I had to guess I would think TORS or speedo sensor.
jromain
- Nov 22, 2009
thanks
there no codes flashing,
does it log inactive codes
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- Mine did something similiar?
- I got the Triangle Warning light and the TEMP warning sign. No codes.
- Figured I was overheating, so just shut 'er down and cooled it off??
Honk
its warmer now so the warnings will happen much quicker. try getting some snow to fly, it'll cool down.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Yeah, you might be getting an overheat warning light. It doesn't flash a code. Check your owner's manual and match the symbol to see if it is or not.
monte1214
- Apr 20, 2005
- Durham Region, ON
- I don't have an owner's manual, just the service manual and nothing is mentioned in there.
- Hopefully some wiseman chimes in and informs the masses.
:rules
:rules
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I had two guys with this error. Both were NOT the same thing. One was over heating so we put in more vents and that was that. The other one had cook alot of wires. Yamaha give him a new sled it would have cost yamaha more to fix it then give a new one. Yamaha told me they still dont know y it did that.
Tycho998
- Feb 26, 2008
- Cornwall, Ont
- 2006 Attak
I just had this happen to me this Sunday... Twice on the very last day of riding. I stopped by the Yami dealer on the way home and they pulled up the history. It was 20 and 30. The mechanic looked it up and the book said it was a low oil pressure warning. We check the oil again, it was just above "E". He thinks the the sensor is sensitive. Not sure where a litre+ of oil went in 2500 km but... that will be a summer problem.
monte1214
- Apr 20, 2005
- Durham Region, ON
Tycho998 said:I just had this happen to me this Sunday... Twice on the very last day of riding. I stopped by the Yami dealer on the way home and they pulled up the history. It was 20 and 30. The mechanic looked it up and the book said it was a low oil pressure warning. We check the oil again, it was just above "E". He thinks the the sensor is sensitive. Not sure where a litre+ of oil went in 2500 km but... that will be a summer problem.
- HMMMM???
- Funny you say that...when mine came on, I was looking all over as to why and just happened to pull my sensor.
- When I pulled it, there was a "drop" of oil down in there. I dabbed it dry, waited for the sled to cool down ('cuz I still thought it was running hot) and away I went.
- 1st...how would oil get into there?
- 2nd...maybe the sensor is a little sensitive????
rc2ubro
If im reading correctly monte1214, you are thinking that the oil tank is the coolant overflow. The silver tank with a dipstick,which has a plug on it is the oil tank and yours needs oil quick!
Tycho998
- Feb 26, 2008
- Cornwall, Ont
- 2006 Attak
The Oil sensor is also your dipstick. Pull it again and look at the side of it and you will see the the levels...and there should be lots of oil on it.
