srx70024
I just received my Apex GT and noticed is has a "clacking" noise when running. I haven't heard too many of these run, so this could be normal. Should I be concerned?
What an awesome sled. I can not wait for the snow now. Thanks Yamaha for such a fine piece of equipment.
YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
srx70024 said:I just received my Apex GT and noticed is has a "clacking" noise when running. I haven't heard too many of these run, so this could be normal. Should I be concerned?
Most likely it’s the clutch. The RX had the same type of noise. I wouldn’t’ worry about.
srx70024
Thanks Moose.
Tork
Fuel injectors can also make a klicking/semi clattering noise. I'll pay more attention as I have only had my apex running for about 3 minutes
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
My RTX makes the same chatter. It is comming from the clutch side of the sled. Haven't had to the time to investigate it yet. It probably isn't anything. When I really run her for the first time, we'll see if it clears up.
1CS
1CS
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
Most likely the reduction gears.
Slush Monster
Most likely what you hear is the clutch. If you think the 4 cyl. is bad you should hear the 3 cyl. 120 vector clutch. My rage had a nasty rattle all the way up to 5500 rpm even after I installed the o ring kit it was still bad. The cluth noise in my attak is much better,only a little at idle but it goes away as soon as I rev it up.
NOISE
Wife's new APEX GT is a quit as a mouse except for the exhaust purr.
daveh
- Apr 29, 2005
Hmm, I don't hear much and have run mine at idle twice but all sleds I have ever owned make some sort of weird noise when starting out.
No worries yet
Give it 20-50 miles.
No worries yet
YammiMoose
- Mar 18, 2004
Just remember, their is no exhaust pipes in the front of the sled to muffle the sounds coming from thinks like the clutch and the reduction gears. On my RX1 I spent the first miles listing to strange noises than turned up the MP3 player and never looked backed....
