derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
what engine oil are you guys all running in your rx1? New to yamaha this year and definitely new to 4 strokes, only has 1900 miles on sled but would make me feel better before going on a week ride. In my 4 stroke quads I have always ran AMS 4 stroke synthetic and have 6 or 8 quarts sitting around or should I stick with the yamaha brand oil? Any help would be appreciated
yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
IMO you can't go wrong with Ams oil
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I don't think you will find many people who have had bad experiences with one oil over another...except when it gets really cold. I'm trying the Mobil 1 0W40 European formula this year because last year I almost had a no-start on a really cold day (hard to crank) and people have said that the Mobil viscosity is less variable with temperature changes than the Yamalube semi-synthetic that I was using.
yammy semi sythetic 0w30 at most untill you get over 2500miles. then full synthetic would be ok. kirkswim's war has full yamalube synthetic 0w40 in it atm as it starts better with it at -40c. sled has 15000+change km on it. only ran semi untill this season. we had problems not using yamalube in some stuff and going back cured the problem. and yes i was useing wet clutch compatible oil in both applications.
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Ok thanks guys, this thing has been a learning experience already and haven't even been able to ride it!! Did the apex seat swap and 4 inch riser and now my check engine light blinks twice, I know its a hand warmer issue just can't figure out what's wrong with it!
Big T
- Dec 15, 2014
- Fox Lake IL
- 2004 RX Warrior
Yamaha semi 0-30 herewhat engine oil are you guys all running in your rx1? New to yamaha this year and definitely new to 4 strokes, only has 1900 miles on sled but would make me feel better before going on a week ride. In my 4 stroke quads I have always ran AMS 4 stroke synthetic and have 6 or 8 quarts sitting around or should I stick with the yamaha brand oil? Any help would be appreciated
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Amsoil 0-40 full synthetic for over 20,000 miles works great.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Everything OEM for me. Yamaha Synthic 0-40. Mobile 1 or Amzoil in a pinch.
take the handle bar pad off and make shure that all the connectors are plugged in. did that one on my brothers 04 war when i had it all apart a couple of months ago.
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Everything worked as should before I did riser so I'm thinking electrical did a continuity test on both hand warmers both acted fine, I'm sure I plugged everything back in same way only thing that changed was my headlight high low switch is broke now but that don't seem like it should affect my hand warmers
Lol brothers switch was broken for years from a rollover. I actually forgot to plug in the wires connecting both hand warmers to each other on his when I had the pad off replacing left side controls because of a broken mount for his park brake.
