yamahahaapex
Warm temps minimal snow had to stop lots and throw snow everywhere. Engine light and temp light came on flashing these two codes but almost instantaneously shut off sfter stopping for a few seconds. Decided to quit riding for a couple hours and went back to it. No problems all the way home but it was also a bit colder by then. Any ideas?
MikeAttakNYC
i just looked on the error codes list and descriptions in the FAQs section of the forum and the lowest codes are 11 and 12, and (no mention or 1 or 2) and with 11 and 12 starting is impossible i believe
Yamahammer485
Was it ERR1? and ERR2?
These codes show up differently than the numerical ones.
yamahahaapex
yeah your right it was err 1, err2
loligager
I had a similar incident occur on a ride earlier this year. It's been a while, so not certain of the codes but same symtoms. I stopped at the dealer and they said the errors where something to do with the guage cluster. It was cold in the morning then warm in the afternoon when the errors flashed. By late afternoon it cooled back down and the errors stopped flashing. It turned out to be moisture in the guage cluster. There is a rubber boot that seals the back of the guage cluster. The boot had worked itself loose allowing moisture in. I took the cluster apart and dried it out, put it back in and made sure the boot was sealed and the error's haven't flashed since. Same symptoms, engine light and temp light but can't remember exactly the error code.
