boritzer1234
I've been reading up on this since I had this problem happen to me today, but here is my situation and I would like some fresh views on this. I pulled my 08 out of the shed today to do some cleaning and knew that it didn't turn over because I figured the battery was dead. Well i went to jump it just to see how she ran and to hear the baby purr and all I got was click just like the battery wasn't charging. I went up on the trailer and looked and the yellow warning light was blinking with error code 12 which is the crank shaft position sensor. On the chart it said this will prohibit the sled from starting.
An hour or so later I went to put the jumper cables on the battery again and it popped off and was running good. This is when I noticed that i did not have the code blinking at me. I shut it off and started it again 5 minutes later (without jumper cable) and again it started with no code. I let it sit for about a half hour and went to start it and all I got was a click and it wouldn't run (without the jumper cables). I checked and the code still didn't appear. Am I okay or should I worry about the the sensor code? I am going to put a new battery in the machine, but over night I am going to have it on the charger. I called a dealer and they said it would cost me $105 in parts plus whatever labor it would take. What do you guys think?
