error code 20/14
yamahatd
mass
Anyone else get these codes? I started my sled to move it today and had code 20/14. I know from last year having a code 20 that it is to do with the intake preasure. When I changed the oil for the first time I notice the air box gasket folded,. I fixed that and it seemed to be fine for the rest of the season. I have not checked the air box since I got it back from the dealer. I had a lot of waranty work done and had them change the oil and filter.
I'll check the air box, but was wonder if anything else would be setting this code off?
Thanks for any help :Rockon:
i threw the same code (20) when i changed my oil. maybe the dealer never checked and cleared all the codes. i cant remember what 14 is. my service manual is at work. i would reset the codes and see if they come back.
Check to make sure the air pressure sensor is pluged in. The 14 code is for a problem with that circuit.
Thanks for the heads up on code 14. I am planning on remove the air box to check the connection between the box and throttle bodies. A bad connection from the factory set off code 20 last season. I'll check the connection on the sensor. ;)!
looked at my manual today at work. both are for the air sensor. 20 is a open circuit and 14 is a malfunction from the sensor.
