vteckiller
I got exceel exhaust. Install was easy and it sounds great. I just put some gas in the tank that i had laying around the garage to start it. it ran bad so i got new gas. After that it runs great but now the fuel gauge is blinking and the warning light is blinking. So why are they blinking?
yzman
Check again to see if the gauge is telling you a diagnostic code?
vteckiller
where would that show up?
yzman
it will show up on the gauge where the speed is indicated , if i remember it will say code xx (xx = numbers )
vteckiller
nope. nothing theres just the speed a blinking gas gauge blinking gas pump and blinking warning light
yzman
I will check my manual for your problem , ill report back if i finds out any info
yzman
sorry man i thought i knew where my manual was , but ill have a look for it
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You didn't connect your fuel gauge is why it is blinking at you.
vteckiller
sob. k ill tear into and see thanks for the info
vteckiller
wheres that at? because the electrical connection ontop of the fuel tank is plugged in
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
the float connection should be at the top front of the tank, like on the engine side of the tank.
vteckiller
perfect! that was the problem!
vteckiller
