terret725
I want to make a custom exhaust for my Phazer with out cutting up my exhaust. i need the flanges after the donut and ones off a apex look the same but I'mI'm not sure the size, actually vector, FX Nytro and apex all use the same part numbers for the donuts but the Phazer is the only one different. i was just going to buy a used Phazer exhaust to cut up but cant find one for a reasonable price. so i was thinking finding the Y pipe off a apex will be a lot easier to find and a lot cheaper if they flanges and donuts are the same size.
thanks in advance to any one that could measure them up for me
LJ 452
I've got a Y-Pipe off an Apex for you, problem your going to have is they're $300.00 and made of Titanium so moding it won't be easy or cheap. I would sugest an RX-1 Pipe as they were made of stainless so even if you find an old worn out one for cheap it could (should) be repairable. Same donuts were used in the RX-1's.
- 12K
