cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
Digging further into the 2006 Attak for summer maintenance and I have the seat and gas tank off to replace the exhaust donuts with the copper ones I picked from Sledtoyz. I have reached the band clamps and the bolts are really rusted on. Got some PB and going to use some heat to get them off. Does anyone know what size they are? I'd like to replace them with stainless hex bolts to help prevent rusting and make removal the next time a little easier.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Stock OEM donuts come with new bolts.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
what teamblue4 said, you will need to take one in somewhere or go purchase new ones from the dealer since you purchased yours elsewhere. Also i filed my clamps down just a bit so that they close tighter when i changed mine out.
Are you talking about the clamps to join the Ypipes to the muffler or the clamps that hold the Ypipes to the flex pipes?
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
Actually, both. Both the hex head bolts holding the band clamp flex pipe to Y pipe are rusted together and the star head bolts holding the Y pipe to the tunnel are rusted and the heads are stripped. I have the OEM part numbers. What I was looking for was the bolt sizes so I do not have to order 1 of each and then go purchase a stainless steel version.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I know that I replaced them all but can't remember sizes off hand, I'll see if any of the old ones are around in the garage. If you have calipers you can measure the OD and they are metric so they should measure slightly below the nominal thread size.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Can't find any old ones but measure yours and you will know what they are (5.8mm OD = M6 thread, 7.8mm OD = 8mm thread, etc). I had to drill out the rivets and remove the hanger bracket to replace those screws.
