So I did an oil change on my Phazer a while back and removed the weep hole bolt in the exhaust to check oil pressure. Weep hole was more like a stream of oil. Got all over the exhaust heat shield insulation/fiberglass. Cleaned up and put it back together. After running the sled to burn off the oil it started on fire. Insulation is still loaded with oil so I had to order a new heat shield 8GC-14627-00-00. Problem is it's on back order and no ETA. Any idea what I can put in there for the mean time that won't burn or catch on fire? Can I run without the insulation. Almost lost my sled - good thing the garden hose was still hooked up and not frozen because the fire extinguisher couldn't get to the fire.
RoicIND
I have one of the header heat shields sitting on the shelf at the house.
As an added bonus, I'm right outside Saratoga.
PM me...
PM me...
What a guy!Saves the day.That must have been scary Jkraeger
phaze5
looks like a road trip is in order.
That is why this site ROCKS
RoicIND
HEat shields
Jeff,
I have both the upper and the lower! I'm heading to Old Forge for the weekend if you'd like to meet somewhere along I-90 or 8/12 Friday evening, I can save you the shipping hassle and delay.
Jeff,
