LazyBastard
Anyone who has actually worked on the insides of shocks.... I've been reading the expertx suspension manual, and they have a minimal writeup about recalibrating the shocks.
What I've been able to determine is that to increase compression damping, add shims above the piston, and to increase rebound damping, add shims below the piston.
My questions are these;
1) How do you determine how much shim to add or remove?
2) Where do you get these shims?
3) Where do you get the nozzle to refill the n2?
Now my two observations regarding the performance of the suspension are these; a) It bottoms out more easily than I'd like, b) It bounces back up real hard (a$$ kicker). I think I should increase both compression and rebound damping, right?
