YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I just used Mother's Polish on the running boards and it worked great but spending all that time there made me notice how many unused rivet and skid mounting holes I have after swapping skids. What options are there to fill them in with something that looks half decent other than just using rivets?
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
y not just put rivets in them?? Will look factory again.
Nick1945
raginyamaha said:y not just put rivets in them?? Will look factory again.
X 2. That would be the easiest way to do it.
yamadog1
rivots
the extra holes you have to the front are not in mine so did you drill for some other skid?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Re: rivots
Yes, replaced Proaction with Monoshock so I have one big hole and a bunch of small ones that are no longer needed. I thought rivets would probably be the way to go for the small holes but just wondered if anyone has done anythig different?
yamadog1 said:the extra holes you have to the front are not in mine so did you drill for some other skid?
yamadog1
bolt
maybe you could put small chrome bolt in larger holes, also the more you polish the better it looks, hard work but it looks nice also you have to keep after it.
Svartstreck
For the larger holes, just grind the square section down and thread it, put a nut on it inside of the tunnel =)
I've got no idea what these are called in english though.
One of those chromed antenna hole covers could work as well, if the rubber gasket is removed
lawmanbsi
I had a piece of stainless steel cut to match the profile of my tunnel when I changed to the Expert X. I had a huge hole from the mono skid dial in the tunnel.
ZapeX2
I just filled holes with stainless rivots. Get a short stainless carriage bolt and nut for bolt holes. I used tunnel supports to cover up the shock adjuster hole but I have seen people use a big yamaha symbol there, similar to the ones on the tank cover,,,, looks good to me....
Alatalo
- Jan 11, 2005
Each Yamaha chassis rivet is two grams after mounting. You are not saving a lot of weight by leaving the holes empty...
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I ended up using rivets in the small holes and I found these 7/16" chrome buttons at Home Depot. The trick is that they don't retain very well on their own so you have to bend the tabs over from behind and that's hard to do if the hole is behind the skid mounting plate (but not impossible) so it's easier to do while you have everything apart. Only time will tell if they are going to rust though.
stomper
A little hint with the mothers is when you go to buff it off use some flour on a clean cloth and it will bring out a mirror finish with out to much elbow grease. But according to your pictures it looks like you have it all figured out how to get a mirror finish.
wpgwarrior
pic
nice lookin sled lawman
Alatalo
- Jan 11, 2005
Also, Mothers Billet Polish will bring out a better finish than Mothers Mag & Aluminum Polish. In my opinion, Mothers Mag & Aluminum Polish as well as the Busch Super Shine stuff is a bit too aggressive as they dull the perfect mirror finish by leaving microscopic but still visible scratch marks.stomper said:A little hint with the mothers is when you go to buff it off use some flour on a clean cloth and it will bring out a mirror finish with out to much elbow grease. But according to your pictures it looks like you have it all figured out how to get a mirror finish.
