Extro question
Srxspec said:
I have both the Wahl 9 tooth and Avid 9 tooth drivers available. Call me if we can help you.
This is what I'd do, I'd call Allen. When I eventually need my 9 tooth 2.52 pitch extros on the beefy shaft, I'm calling Allen, that's for sure.
I just sold my 8 tooth extros, 2.52 pitch on the beefy shaft last week because I didn't want to lower my gearing by going to 8 tooth on this sled quite yet......
:Rockon:
MikeAttakNYC said:
Supersled, would this be the correct wahl bros drive for my attaks drive shaft with 9t and 2.52 pitch? (curious about which diameter I need). Think I'm gonna go with the wahl bros they are considerably less expensive
If you are going with a Cobra track, I'd stick with stock size 9 tooth drivers, unless you want lower gearing. Switching to 8 tooth drivers will lower your gearing a tad (assuming you stick with 2.52" stock pitch)....
9 tooth, 2.52" pitch is stock. Stock just are not extros for some silly reason by Yamaha, probably to save $10 on the sled's cost........
