YamYboY
looking at putting a 9 tooth drivers one my 08 RTX, just wondering what the shaft diameter is?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
1.0625"
YamYboY
can skidoo drivers be used?
gems4sale
- Dec 20, 2008
- Hampton N.B. Canada
- opalrough.ca
They are for a slightly larger diameter shaft I believe. There was a post about putting the plastic cover from a duotang folder around your shaft and press the BRP driver over that. Trimming it up afterwards. I wouldn't like that idea. Avid drivers should have all you need. Talk to Robby. 406 862 6296
NLVMAX
- Jan 18, 2008
Mine from http://www.avid-products.com/ And it was Ulmer who led me to these guys.
9 Tooth, 2.52 pitch, 1.0625 axle.
skidooboy
avids are the shiznight. ski
Nikolai
Fo Sho
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Doo drivers will work, its what I have on mine. However I think they are only avalible with the axle shaft now. When I ordered mine, they changed part #s and came mounted on the axle shaft.
The Doo shaft is 1 1/8". After I pressed them off the shaft, I put them in a large pot of boiling water for about 45 minutes. The wife loved that one!! Anyway the hot water softened up the nylon to allow the center to shrink down to 1". So they fit tight on the Yamaha shaft.
If I was to do it again, I would just get Avids.
