fault code 14 on apex
golfaddicted
Spokane, Wa
Will fault code 14(intake pressure sensor) on apex which fail safes the intake pressure to 85kpa(~12 psi) cause the motor to run extremely rich? thanks guys
85 kPa (25.1 Hg) is an altitude air density of 5000ft and the air fuel ratio would also depend on what the other factory sensors are feeding the ECU ... I wouldn't continue to ride it with this fault, if that's what you're asking, unless I was just limping it back to the trailer so I could get it home and fix the problem.
Thanks for the response
Thanks Hammer. I'm not riding it. I had to limp it out on Sunday. I think I just found the problem. The line going to the fuel controller was torn. It caused that fault. I'm going to change the oil and put new plugs in and try it out. Thanks again for the response.
It worked
I fixed the pressure line to the fuel controller, cleared the codes and it ran great. Problem solved. Thanks.
I ran mine inside some standard automotive line to protect it ... ;)!
Where is the pressure line and fuel controller located
