Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Well I pulled the pistons out of my apex , the compression rings are stuck in the pistons seized in from condensation possibly but now I know why it worked fine when I parked it then wouldn't start the next fall lol re ring it and put it back together will be good as new
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Well that sucks, hopefully everything works out.
Curious, what grade of fuel did you leave in the sled? Did you use any fuel stabilizer?
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
That's why I run my sled monthly or so in off season. When ever you start one of these four strokes make sure you run it long enough to get it good and hot so it burns up any condensation from cold start. Did you by chance only run it a small amount before parking it at the end of last season? I remember a story of a guy that started a sled (cold)ran it in his trailer and wen't back a month later to start to put in storage and it would not start. Ended up having no compression with valves all corroded.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
No I never put anything in the fuel it was stored in a Quonset usually run about a 1/4 of av gas or octane booster in every tankWell that sucks, hopefully everything works out.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Ya
That's why I run my sled monthly or so in off season. When ever you start one of these four strokes make sure you run it long enough to get it good and hot so it burns up any condensation from cold start. Did you by chance only run it a small amount before parking it at the end of last season? I remember a story of a guy that started a sled (cold)ran it in his trailer and wen't back a month later to start to put in storage and it would not start. Ended up having no compression with valves all corroded.[/QUOT
No it was parked and only started up for a few seconds in the summer then shut off the rings are def stuck good in the pistons oil rings nice a free I have them soaking right now hopefully by Monday rings will be free , ya I could see could see it making condensation will be starting it up lots from now on and letting it warm up
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
What fuel were you running in it last? Race fuel by chance?
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Just some premium fuel with some race gas mixed in , when I pulled the pistons the oil rings were free but the top and center rings were seized into the pistons , must have got moisture in engine wax parked in a Quonset with a dirt floor must be where moisture came fromWhat fuel were you running in it last? Race fuel by chance?
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Fog it heavily next year ! Wont take as much work !
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
yep good idea
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
If you were running a rich AFR and the cylinders were getting washed with fuel, the leaded race fuel oxidizes everything steel after sitting. We've had to disassemble cylinder heads that ran race fuel before storing because the valves were rusted solid after sitting... it's like the fuel rinses any lubricating properties away, probably the reason they sell top-end lube addititve for fuel.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Thanks will look into a fuel additive
