I have a "power terminal" that I mounted straight from the battery. It is fused. Then all of my accessories go directly to the power terminal with smaller fuses. Garmin sells a direct power plug/cord, for the 60 series unit.....just 12+ and 12-. very easy. You could go straight from the battery, but I have way to many wires in accessories to do that.
Garmin sells a power cord for the purpose of hard wiring. Just a 12+ and a 12-. You could go straight to the battery, or the jumper cable. I have and accessory terminal block that I mounted for all my accessories. It has a larger fuse. Then anything I hook to it gets a smaller fuse. Works good. I have way to much crap to go straight to the battery with everything.
Hey Sleddog, I'm going to pick up a set of USI triple threats here soon and plan on putting a set of Deuces on them too. How did you like that setup last year? How did the sled handle?
