first check-up
MadMax
Gobles,mich.
Does anyone know what they do during the first check-up. I've been doing mine for 25 years.. But this is my first 4-stroker.. I'm thinkin' the valves/maybe the carb sync. I would do everything else. Fluids/track adj./pri-chain adj./oil change/Maybe by then yammie will have a fix for the clutch rattle... "MY" only complaint..MM. :ORC
I left my book up north, no valves til 20-25 k, carbs too
I think if you do your filter and oil you are good to go.
1st check up is usaully oil/filter,check track tension and chain case tension, grease suspension and a few other things. If you are handy you could do it yourself.
Yup! I can do that. I just posted about the cam-chain adjustment. If it's self adjusting or not. MM. :ORC
