fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Probably worth the peace of mind
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
Is there any way to tell if the subframe on my Nytro is the original?
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Is it bent? It's original [emoji12]
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
Haha! I don't think it's bent!
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
08 subframe I believe is the one that lacks a big hole in the bottom plate between the lower arms in the subframe.
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
Ok, I think it's the original then.08 subframe I believe is the one that lacks a big hole in the bottom plate between the lower arms in the subframe.
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
Heavy frost & sub zero temps the last couple mornings!!!!!!
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
yea and the newer subframe is to soft also. I have the 09 sbframe on mine and its bent, i ride hard tho
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
How weak are they actually? Will they bend under normal riding weak or are you talking hitting jumps & stuff? This is my first sled so I doubt I'll be to crazy, I'll probably spend the first winter just getting used to it & how to drive really. The gusset kit is way over my mechanical ability so I'm going to have to hire someone to do it, I'll probably leave it this winter & get it done over the summer.yea and the newer subframe is to soft also. I have the 09 sbframe on mine and its bent, i ride hard tho![]()
yamahamm
- Oct 9, 2009
- Norway
ist not so soft, but i have hit some trees with my skies from time to time and bent the subframe. But on my old sled a yamaha mountain max i also hit trees but nothing happened then
But i just ride my nytro with the subframe i have on. Nothing to worry about until its to much bent tho.
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
Is it a big job to change the crank cover gasket on bottom of the motor? I noticed it's leaking a little bit when I took the skid plate off.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
check your airbox for oil in there. the pan cover never leaks, unless it was previously taken apart and not put back together rightIs it a big job to change the crank cover gasket on bottom of the motor? I noticed it's leaking a little bit when I took the skid plate off.
HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
Ok I'll check that out, but I'm 99% positive it's leaking at the seam on the front side of the cover. I wiped everything down really good a month ago & there is 1 small drop on one of the screws, you can see that it came from the seal.
