homeplaya
- Feb 16, 2010
- montreal
- www.nobelmetals.com
I am changing my runners on 2011 se after 800km,
I was told that I would need to take off the suspension to
Do this, does this make sense???
quebecmoutainrider
there is a video on youtobe that shows how to get them off by putting the sled in reverse..they just peal off..and you dont take the susppention out..unless you want to do it the hard way..try search you might find the thread
snowbiscuit
I am on 3rd set on SE and I pull suspension, not too bad a job. With upper idler now fixed to tunnel track stays in place... only have to contend with front rivets when reinstalling
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
You don't need to remove the suspension to change the sliders. You can fit them through the track windows.
800km huh?.....seems to be a common theme...too bad.
homeplaya
- Feb 16, 2010
- montreal
Grimm said:You don't need to remove the suspension to change the sliders. You can fit them through the track windows.
i dont think its the machines fault, been riding with very little to no snow,
been through 2 sets of carbides already also, just want to ride snow or no snow
Raypex
Look up "Nytro Hyfax J's Garage " on you tube, this should get you there. The method works well, did it a few weeks ago and the guys (including the mechanic in the bunch) were amazed! just make sure you get the old hyfax to stick out a few inches.
