Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
First time I've seen this when I accidentally saw it while searching for something else. Seems to be a viable solution to cracked pipes and broken flex joints. Anybody ever try this kit or something similar? Probably could DIY your own kit if you can source the appropriately sized flex joint.
https://www.kijiji.ca/v-view-details.html?adId=1383705103&siteLocale=en_CA&requestSource=b
I am in no way affiliated to this guy. Just passing it along as a solution to broken exhausts, which I would have loved to know about when I broke my pipes twice
I know a few guys that have used it..Great replacement....Well worth it..
I did it and it’s a nice mod ! Will see how it holds up , but by the looks of it will be better then the the donuts !
I used my stock Y-pipes , need to cut. If you have aftermarket pipes like I have the cut is slightly different. I cut Y-pipes and the new flex pipes to get fit better . Let me know if you have an issue
FXGarageWorks
- Nov 2, 2018
- Erin On.
- RX1,Apex,Nytro,Phazer
Hi there, more information on this part is available at www.fxgarageworks.com. You can call to buy at 519-315-0157. The option to buy online is coming soon.
YukonMP
- Dec 25, 2014
- Yukon Territory
Welcome aboard. Thanks for coming on as a vendor, makes the powers that be happy.
I utilized some heavy duty couplers back in 2005 when I built the header for my Rage. That project was more in line with looking for gains, as we didn't know too much about the failing exhaust donuts at that time.
https://ty4stroke.com/threads/custom-high-flow-header-and-flex-couplings.21102/
Are the couplers smooth inside?
FXGarageWorks
- Nov 2, 2018
- Erin On.
Hi Brian I would really like to see the pictures of the couplers but they seem to be blocked. Can you send them to fxgarage@hotmail.com Thanks
