martini
I flooded my RX-1 pretty bad getting stuck on a steep climb, ever since it is more difficult to start, and wants to stall coming downhill,
it is a2003, rx-1, with an Mcxpress rear mount,
thanks for any help,
Ted Jannetty
martini said:I flooded my RX-1 pretty bad getting stuck on a steep climb, ever since it is more difficult to start, and wants to stall coming downhill,
There is probably fuel in your signal lines and intercooler, you should pull everything off and dump it out.
Ted.
whitee
yep your intercooler probably has 1/2 gallon of gas in it
martini
great , thanks for the info guys!
Yep for sure your problem!
Turbo Tim
While you're at it re-wire the fuel pump to run only when the engine is running ( not when the key is on) . Blue and white wire on the fuse block if I remember right.
