FLY Adjustable Riser
ISLANDRACING
NEW YORK
Website
www.islandracing.net
Here are some pics of the FLY ADJUSTABLE RISER on the Apex.
I feel the Fly riser is one of the trickest risers on the market. I basically wanted a stock height pivoting riser with the ability to raise and/or pivot the bars whenever I want. It takes longer to get the wrench out of the tool bag than to raise the bar.
I machined a Powermad 2" block down to 1&1/2" and also machined to accept the stock chrome trim ring. RSI Pivot Adaptor, turned down socket bolts to fit the adaptor. I didnt want to drill the steering colum. this keeps the riser at stock height when in the lowest position. Undecided if I want to use the stock pad or not.
Sweet! Are those stock handlebars? I was thinking of posting a topic about this. I have a 06 Attack with the stock riser. To ride standing up comfortably I need something taller. I was thinking of the stock mountain block. They are going for about $90 though. Anyone know how high you can go with stock cables or if they are the same length as the mountain?
Looks good ;)! I took my stock pad off,its not going to do anything if i smash into it .looks better to me anyway. :drink:
I like the way that looks like it came from the factory that way.
You can get 2" more out of the stock cables.
Muffin works told me you can go 2" higher without having to extend cables.
