Fly Areo bars + 90deg ends + Yami heaters = which grips?
mewaschuk
VT
Anyone have experience with which grips best fit the Fly bars with 90deg ends and yamaha heaters? Thinking ODI but can't find anyone using the yamaha heaters to confirm they fit? Any install tips when using heaters?
Ever look at RSI gel wraps?
The ODI grips are a perfect fit......... plenty of length too.
Instll tip: Wrps the bars/heting elements with hockey/friction tape, then spry the tpe nd inside the grips lightly with brake/carb cleaner...... work quickly and they will slide right on. Once dry I use two wraps of safety wire to lock em in place. Rock solid!
odi much better, after one season of rsi grips the gel ones the were done
Yamaheater will work with any brand of grip heaters, Yamaheater is just a controller of the grip heaters, not the heaters themselves.
RSI heaters are fine, not sure about their grips, Yammie uses rsi heaters in the kit they sell.
Good info. Im using the oem yamaha mtx heaters for the longer cable length.
I used the ODI as well. What I did was put one wrap or electrical tape on the end of the heater and put the RSI grip glue on and pushed the grip on then put 3 zip ties on the grips and let them sit for 3days took the zips off and I can't even twist the grips no matter how hard I try.
